E
elsparko
and yes i mean 3 or 4 not 3 quarters! lol
Discuss SWA cables - fly leading armour as cpc?? in the Talk Electrician area at ElectriciansForums.net
Yes agree Bob, with respect "elsparko" not really something I would ever do. Don't think that would comply with the Regulations. On a par with snipping a few strands from a conductor to get in into the terminal. IMO.How are you doing that and following manufacturers instructions in using the glands?
Also i'm reading that as 3 to 4 stands rather than 3 quarters. In which case, will do nothing anyway.
Aside from this, have you ever seen a properly terminated SWA gland just loosen on it's own?
If I saw this practice on one of my jobs I'm afraid I would insist on having it remade.
i dont do this on outside glands for this very reason, but standard glands its always been a force of habit, monkey see monkey doIt's a poor way of doing it an unfortunately as you've now no longer got evenly applied pressure all the way round the gland seat, it's actually more likely to come loose with vibration.
It would compromise the IP rating of certain glands also.
Agree with Bob again, you have been taught the cowboy way I'm afraid, I would use PIRANHA locknuts as the locking ring for the gland an take a cpc from the connection on that locknut, beats having banjos or frying pans as you refer to them littering up the enclosure a far better and neater way of doing the job IMO.Sounds about right for a farm.
No you shouldn't be doing it, the glands aren't designed that way. As for a reg, I can't remember the number but it's something along the line of "suitable electrical and mechanical termination"
@elsparko
I would stop this practice asap, regardless of who taught you this or what field of electrics they worked in, this is poor to bad practice, I would also question the quality of their working practices given they felt this was an acceptable method.
The glands are manufactured to certain tolerances and the SWA has to also be to similar tolerances so that the glands are more or less universal to the given size on their packets thus will fit what it says.
The glands rely on a full use of the strands to maintain an even grip all round, taking a number of strands away and routing them direct to the earth will give a poorer glanding termination and the remaining steel strands you have secured will not satisfy the reg's, under fault conditions the gland or strands brought through could fail and/or see damage done to the cable.
Your R1 + R2 tests and ELI do not show all issues and when 1000+ amps flow under fault conditions your gland should be fitted as per manufacturers instruction as the regs require you do.
If you secure and tighten your gland correctly it should not come loose, if due to environmental conditions you suspect the glands could loosen then serrated washes should be fitted, there is also the case that the installation requires regular inspection and this should pull up on any glanding issues.
In my experience of 30+ years I have never seen a gland come loose that was fitted correctly and suitably done to account for environmental conditions so I do not see this practice serves any purpose, the only glands I find loose etc are down to poor termination practices of which I would put your method as one.
https://www.google.co.uk/search?q=p...x-b&gfe_rd=cr&dcr=0&ei=WNl5WrSMNamn8weSkoGIAQwell i stand to be corrected and glad to have it pointed out, at the macallans site we used a really thick brass locknut that had screws on the side for terminating crimps to, nobody was bothered about me taking a few strands into the earth terminal aswell though
my first boss we only used what came in the gland pack
yeah thats the ones we used at macallanshttps://www.google.co.uk/search?q=p...x-b&gfe_rd=cr&dcr=0&ei=WNl5WrSMNamn8weSkoGIAQ
Here you go PIRANHNA nuts just the ticket for SWA why the gland makers don't utilise them in their gland packs I don't know
If the armour is used as the CPC then you have no option other than to fly lead. I like the piranha nuts personally.
i should add that it still has a frying pan and flying lead, aswell as the 3 or 4 strands, and a dedicated cpc.
worst case scenario i still want there to be some earthing to the steel wire
Got to ask why faff about butchering the glanding when you have a ready made terminal ?ye
Thanks Dave you live and learn.The company who make piranha nuts do supply gland packs with them in.
Obviously other companies don’t supply their competitors product in their own gland packs, nor can they easily make a copy due to copyright and patents laws.
32 posts late with that, Pete.....piranha locknuts - Google pretraga - https://www.google.co.uk/search?q=piranha+locknuts&ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&dcr=0&ei=WNl5WrSMNamn8weSkoGIAQ
True harmonySeen up to 4 banjos linked together.
Better late than never32 posts late with that, Pete.....
i was
i wont be continuing doing it if its incorrect lol, and i never meant that the gland would just come loose, i mean that if some farmer did take it off and couldnt get it back on
i always checked my glands after fitting and none were ever loose, i feel like ive just been making any glanding ive done a harder job than it needs to be though
i dont do much industrial so thankfully not much will be affected, not sure about my old boss though! lol
its been too common on farms to find glands that are just hanging loose, but i digress, i do not know how farmers minds workI don’t understand what difference it would make, surely if said farmer is taking the gland/cable out then he would take the strands out of the earth bar as well, he then surely won’t go to the hassle off putting them back in if he can’t even put the gland back on correctly?!?!
Reply to SWA cables - fly leading armour as cpc?? in the Talk Electrician area at ElectriciansForums.net
