Swa cutter | Page 3 | on ElectriciansForums
Discuss Swa cutter in the Electrical Tools and Products area at ElectriciansForums.net
Since this thread last had an airing I had another go with the Kewtec cutter. After a couple of failed attempts I had a close look at the blade and noticed the teeth were the wrong way round.
I pulled the blade out of the plastic disc with a pair of pliers and lo, it's just a 20mm length of Junior hacksaw blade wedged in to the holder. I imagine that the official replacement blades are ÂŁÂŁÂŁ. I just reversed the blade and pushed it back into the plastic slot and it works fine on cable sizes up to 25mm4c
@BlueToBits
I found this as well with mine, as the blade was running backwards and not scoring the steel wire that much. I turned the blade around in the holder like you said and now it seems to work better.
Reply to Swa cutter in the Electrical Tools and Products area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
