SWA Earthing | on ElectriciansForums
Discuss SWA Earthing in the Australia area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
a query. If wiring to a sub, e.g. in a garage in SWA, using 1 core as earth, armour is earthed at supply end. My question is--- is there any reason not to also earth armour to the earth core at the sub end
agreed, just a belt and braces one. i use the SWA locking earth nuts, so no need for banjos, seems a pity to waste the nut's earthing facility
You not heard it whispered in dark corners that if a fault occurs and you connect both ends of a SWA you will create eddy's.
It's the same theorists that all bonding conductors should be kept tight as if there is a fault and 100's amps go down the condutor it can whiplash ...................
I must go to some wierd places
This type of thread has been going on for years personally i will allways gland both ends wether i insulate one end would be on the instructions of a qual.elect.engineer ,but it would be informative to get a definative answer from the IEE on where and what to do.
yours gb
Im not sure that eddy currents will flow in the event of a fault in a multicore armoured cable as the protection will clear the fault in such a short time that the eddy currents will not have time to establish and cause damage ie heating. Also if one core is being used a sthe earth then it is enclosed within the magnetic armour and will be cancelled out. I d know that single core cables with non magnetic sheaths should have the sheath bonded at one end only as during normal service eddy currents can flow and cause heating of the cable if both ends are bonded.
Reply to SWA Earthing in the Australia area at ElectriciansForums.net
You would treat it as a TT installation.
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
