SWA for 3 Phase Installation | on ElectriciansForums
Discuss SWA for 3 Phase Installation in the Electrician Talk | All Countries area at ElectriciansForums.net
There seems to be a tendancy now to wire single phase installations with 3 core SWA and ignore the armour as a conductore. What is the favoured way of installing 3 phase? 4 core T&N wth armour as earth, or 5 core TN&E? Indeed, is 35mm 5 core generally available?
Normally a 4core ,but if it was a long run you might have to run a seperate cpc so it might be an option to run a 5core if its in stock? also the cores might be white.So its down to calcs./spec./avai./& price
yours benji
I suppose if cost is important there is nothing wrong with using the armouring, as long as the locknuts are tight and don't corrode, work lose, ELI reads OK etc. Using 5 core eliminates this possibility so I would always go for 5 core, and have no problem getting hod of it.
I personally have never installed 5 core SWA and have only seen it once.
I can't see a problem in using the amour for a steel CPC and larger than 50mm cable running a seperated eath cable to reinforce the Ze
I think it comes down to personal choice,
I would say that if you base your costings for the more expensive option and the if the budget gets tight on the job, then you can change the spec for the cheaper option.
(this is assuming you haven't detailed the exact cable)
I think this is one for personal choice and there is no right or wrong answer
Richard
Thanks for all your answers. I think I'l use 4 core and check R1 vv R2 before going to the expence of running a seperate CPC.
Geoff
theres a reat page in GN1 that tells you if the SWA will be suitable for a CPC cant remember the page if i remmember correctly above 35mm 4c a seperate cpc has to be run and also some 16mm. double check first.
as for usinf a 5c remember the cpc can be smaller than live conductors so a seperate cpc will be cheeper.
If the installation is TN-S it would be prudent to lay a CPC of the same cross-sectional area as the conductors in a 4-core SWA cable in addition to securely bonding the wire armouring.
I've checked GN1 and it makes it quite clear that 35mm SWA has not just a little bit more than the required CU equivelent armour, but much more than adequate. Using 5 core or an additional earth is therefore not a requirement.
Regards,
Geoff
Reply to SWA for 3 Phase Installation in the Electrician Talk | All Countries area at ElectriciansForums.net
Came across 3No 1ph heaters connected by 2xT&E cables from a 3phase supply on an installation whilst carrying out an EICR few years back...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
