W
woodysparks
i have a question, i have inherited a site where new lateral swa has been installed, at the distribution end (ryefield board)the swa has been terminated into trunking and bonded via banjos and onto a main earth terminal, which im satisfied with, However at the tenants end the there is nowhere to terminate the swa within a mantel system, the swa has been brought into the mantel and grometed where the metal had been drilled, then the swa was stripped and made off without a gland and the 3 cores were heat shrunk to achieve double insulation to feed the meter and main earth terminal, and finaly the swa has been cleated to the back of the mantel so the cable does not move.
looking at the way the job has been installed it is not unsafe nor it does not breach any regulations.
i have now been asked to respond to the client with the relavent regulations that make this conform does anyone have any comments ?
