SWA long 140M run please help!! | Page 2 | on ElectriciansForums
Discuss SWA long 140M run please help!! in the UK Electrical Forum area at ElectriciansForums.net
F
FCC5206
Evening all
I have been asked what size cable will be required for a long run. I know there are heaps of threads on here from people too lazy to do their homework but I have and am still lost so sorry if this has been covered i just cant find the answer.
The run is to power a stable block which the customer has told me needs power equivalent to a 2 bed house!!
The length of the run is 140 meters!
Taking into consideration max demand and diversity after doing my voltdrop calcs i come up with a 2 core 95mm2 to achieve the required 5% drop!! I know this is absurd and was wondering if anyone could point me in the right direction
Chris
OK, so tell what loads are expected, and we can go from there.
i can't imagined a stable block requiring a huge demand
i can.
build some stables on a greenfield site and you then have an established footprint of an existing building. then, a few years down the line, apply for change of use and get planning permission for a house. and, oh look, we've already got a 100A supply, how convenient!
when you do get your definite max demand figures, don't forget that it could still be cheaper to run it with parallel supplies, ie 4 core SWA. Also the larger size doesn't need to go all the way from source to load. You can take minimum cable size for fuse a short distance, connect it to upsized cable for the long run, then downsize it back for final connection to load. 140m is a long way; hope it's being trenched, and not ducted!!
Reply to SWA long 140M run please help!! in the UK Electrical Forum area at ElectriciansForums.net
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
