V
Vilasalvas
Hi, I wonder if someone could answer this one? Due to a mistake, the garage at the bottom of the garden (80mts away) had 3 core 4mm SWA run to it. When this mistake was discovered by the contractor he ran a second 4mm SWA to the garage (when it should of been a 10 or 16mm cable). Anyway the upshot of all this is, one of the electricians (both part P) would like to run 2 separate 4mm supplies using the 3 cores as live, neutral and earth. The other, however, is looking at using one SWA with all three cores running a LIVE and one SWA with all 3 cores running a NEUTRAL and the earthing being covered by BOTH steel armour covering. Garden has been al landscaped now a third! cable is out of the question. Cheers.
