Hello,
Been to look at job, a barn that's been converted into separate flats. Each one is fed by a 10mm 3C SWA. On peak, off peak and neutral. Currently they just have a double pole main switch for isolation but no protective device. Is there a nice little unit I can use that's designed to deal with something like this? At the moment I thinking of using a 3p&n main switch and then each line on an MCB.
Many Thanks.
Many Thanks.
