SWA (Surprisingly Weird Arrangement) | Page 2 | on ElectriciansForums
Discuss SWA (Surprisingly Weird Arrangement) in the UK Electrical Forum area at ElectriciansForums.net
West Yorkshire
So I’m an inexperienced novice and I accept I know two ninths of four fifths of FA but when was this arrangement ever ok?
Installing like for like replacement garden lights, currently connected to a run of 4 core 1.5mm SWA emerging from ducting under patio. Somewhere further back it’s joined to lighting circuit and then back to 6A RCBO.
Brown and blue cores utilised for L and N of lights.
Grey and Black cores are also put to use, as L and N for an outdoor 13A socket at the end of the garden. The armour is providing the cpc and zs measurements at lights show it’s doing a fine job.
The switch for the garden lights also disconnects the line to the outside socket.
Am I missing something here? I’ve told clients that the socket has to go.
Wondering if you can upgrade the OCPD (mcb) to a 10A. You have to turn the lights on to use the socket. If you not going to use the socket all the time one a or twice a year. I would not care.
I would worry more about the construction and method of jointing the two cables, to which there has been no response as yet.
I'm still waiting for a reply from my post #2 question.....
I'm feeling rejected... :sob::sob::sob:
I’ve no idea how it’s connected to the lighting circuit and I’m not hacking out their floors and walls to find out. Zs is good and, other than the lights were old there were no reported problems. New rcbo tests well from new lights too.
I know what you mean, disheartening isn't it?
Sounds completely unconventional but if it all meets the required Zs and the RCBO trips at the correct m/s it should be okay...I think.
Sorry Alex, I disagree with your post, not out of malice, but, you could say the same with other DIY work, that may meet disconnection times etc, but wired in a dangerous way.
What was the original purpose of this socket? Was it there for one of those annoying pre-fab lighting kits which comes with a 13A plug fitted to it or maybe for fairy lights?
People are so quick to condemn this as a DIY bodge yet there has been no mention of a poor standard of installation or incorrect termination of cables. We don’t know if the original specification was to provide an external socket for the connection of lights to the same switch as the permanent lights.
This is my conclusion after reading the thread. You would hope that an electrician would if contracted to do work would label the socket.
Reply to SWA (Surprisingly Weird Arrangement) in the UK Electrical Forum area at ElectriciansForums.net
