SWA termination and colours | on ElectriciansForums
Discuss SWA termination and colours in the Australia area at ElectriciansForums.net
DoBBY
I can't terminate steel wired armour into original DB as it will not incorparate the gland. Must it be glanded off at the DB or can it go straight into the board without gland?
If so how can I earth the metal sheathing without a gland?
Also 3 core colours are brown, black and grey where can I get 4.0mm sleeving from? for neutral and earth?
Terminate it where though....the DB does not incorparate SWA, it just has big entry wholes for incoming circuits, glands are far too small. I have thought about using tape to identify neutral and earth but is that acceptable (good practice) ?
Then install an adaptable box and terminate your SWA cable into that, and use a flying lead to connect from the banjo to the CU earth bar..... Oh, and use Sleeving to identify your cores, do the job properly
I have seen an armoured glanded off into thin air before now.
Fixed in place to the meter board by a couple of saddles, banjo attached terminated about 7 inches below meter.
In one unit, there was even a fly lead from the banjo to an earth rod, in another unit, no fly lead.
Reply to SWA termination and colours in the Australia area at ElectriciansForums.net
Sounds more positive.
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
