Swapping lights on separate circuits | on ElectriciansForums
Discuss Swapping lights on separate circuits in the DIY Electrical Advice area at ElectriciansForums.net
London
Morning all, I am hoping to swap pendants and spotlights (which are on separate switches) that are above the kitchen island.
Is there a way of extending the connections and putting two pendants where the three spotlights are and the three spotlights where the two pendants are WITHOUT destroying the ceiling with chasing or creating new holes?
I’m happy to pay a professional electrician if need be but little point in wasting their time if there’s no way of doing this without damaging the ceiling as I’ve only just had it replastered.
Thanks in advance
  • [ElectriciansForums.net] Swapping lights on separate circuits
Looks like the joists should be the right way and if you're very lucky, all the wiring might just be in the same ceiling void.
A problem you might incur is that the pendants are probably fitted to timber, while the downlights are away from any timber. Timber support can be added to attach pendants where the downlights are, but you probably won't be able to fit downlights exactly where the pendants are.
Another problem is that the void may be packed completely with insulation.
like the tablecloth. was it from ikea or next?
  • Funny
Reactions: DPG
Reply to Swapping lights on separate circuits in the DIY Electrical Advice area at ElectriciansForums.net
When he bought the bank, they stripped out all the metalwork, iron bars etc for scrap. He was left with the cashier countertops… which have been...
