C
Corpy76
Hi all
I got called out to a fault the other day, main switch RCD tripping. I arrived at the house and the first thing I noticed was that the two very large goldfish in a large bowl where swimming upside down. Anyway the fault was easy to locate a rodent chewed cable in the garage with a bit of damp. Cable cut small IP65 enclosure etc, no evidence of recent rodent activity (droppings etc) and the chewed cable looked like it had been done a while. So power back on and gold fish swimming the right way up.
The customer was a bit concerned about her goldfish so I gave her two possible solutions to provide discrimination between circuits.
1 A consumer unit upgrade to split load 17th board.
2 replace all mcb's with rcbo's and install main switch to replace RCCB.
The question is if she went for option 2 would it have to be a full test as a cu change? Or would you put a limitation on the cert to just RCD tests? Or no certification required as just change of equipment to "equipment of a similar type", and perform a RCD test. Same enclosure Hager with hager RCBO's Main switch etc.
I thinking full test. What do you guys think?
thanks.
thanks.
