in my opinion, the only electrical thing that i would truly trust to last in water is a resin joint. That plant room that flooded, everythiong in it was supposedly ip68. it wasnt. i find that to waterproof JB's and othet boxes, you need to seal the screws with polyeurathene sealant, unless the box is designed to be screwed down outside the rubber seal, and you need to put vaseline on the rubber seal. Everything in this plant room required drying out, and the pressure transducers are shot.
