OP
axel132132
The swimming pool in the house is between 13-15 meters long
Will this still be single phase, or would they need 3-phase
Discuss Swimming Pool in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A 3 phase board for a domestic swimming pool, ....what was it, an OLYMPIC sized pool?? lol!!! Never seen a 3 phase supply for a domestic swimming pool, even for the bigger pools of 12 X 5 metres. Not unless electric heating is included, which i've also never seen on a domestic pool. If heating is required, it's normally via gas or oil boilers through a heat exchanger....[/QUOTE
You need to get about a bit more lol
Maybe, as they may well use a 3 phase pump for a pool that is 15m long and probably be 5 to 6m wide. The main power draw, that would need a substantial supply is if they are using electric heaters. As everyone has stated, you really need to contact the pool company that is installing this over sized house pool, ...Then you'll know for Certain what you need to provide!!!
Hope the owner has plenty of dosh to keep that size of pool running for 8 hours a day, let alone the heating costs to be able to use it without getting frost bite during the winter months in the UK!!...lol!!
Do'nt you believe it , they are the worst kind lol, thats how they have got it.1, I can't see how the pool is oversized if customer has accepted architects proposal of pool and designs from the pool company.
2, if you have the money to have a house built with a pool that size I don't think you will be concerned about the running costs of it do you.
Ask the pool company. They know what's going in, we don'tThe swimming pool in the house is between 13-15 meters long
Reply to Swimming Pool in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
