Switch that switches off all the lights in the house | Page 2 | on ElectriciansForums
Discuss Switch that switches off all the lights in the house in the Talk Electrician area at ElectriciansForums.net
Hi guys
Was wondering if anyone has any information on a switch, that will turn off all the lights off in the house.
I need to know what it is actually called and any advice on how to install it.
I will very grateful for any help
Many thanks
What you're after is known as a 'last man out switch'. It's not necessarily a 'thing' which you add in though, it can be dependent on the way the house has been wired. As others have said you can install contactors on each lighting circuit which are simply controlled from a switch at the front door, like a hotel master switch, but you'd always need to remember to switch it back on when you re-enter the property, turning everything back on which was left on when you left the house, you'd need to re-enter by the same way you left, and as has already been mentioned if you have anything like outdoor security lights, alarms, clocks etc wired into the lighting circuit they will all be turned off when you leave as well.
Alternatively you could have a contactor for every light switch controlled by separate momentary push to make and push to break switches, then a master push to break switch at each exit which cuts power to all the contactors, then each light can be switched back on as needed, like a safety stop switch in a workshop.
Once you have your house wired like this it should be easy enough to swap the contactors for an intelligent lighting system, so you could turn all the lights on and off via an app on a smart phone, which seems to be all the rage nowadays.
Or as Murdoch says you could change all your light bulbs for low energy ones so it won't make as much difference if you leave the lights on,
Or you could get into the habit of turning lights off as you leave a room.
why, exactly, do you need this peculiar function? I believe 99% of the country get by without it?
Hi guys
Many thanks
No need to install anything additional. Just use the one marked 'Main Switch'.
Or if you're happy to spend some money you could get some form of lighting controller system that works via an app on your phone, and shut all the lights off from there if you cant be bothered to get out of bed.. Failing that, hopefully your fusebox will have a switch labelled 'lights' which is pretty self explanatory. Or drink plenty of Peroni and not care about the lights being on until the morning! :)
Hi guys
Many thanks
yes there is one, and you may already have it. Take a look in your meter cupboard for something that looks like this!
[ElectriciansForums.net] Switch that switches off all the lights in the house
Reply to Switch that switches off all the lights in the house in the Talk Electrician area at ElectriciansForums.net
Neutral and live
I was considering that, however the loft isn't boarded, not exactly the lightest 🤣 I was hoping I wouldn't have to do that but maybe that's the...
