Discuss Switched fuse isolator in the UK Electrical Forum area at ElectriciansForums.net
Yes it’s the size really always tight trying to bend the armoured insinde the unitWhat Buzz posted - that is my go-to unit if glanding SWA to it. There's a bigger footprint Wylex unit that Screwfix sell too if you find there is loads of space.
If running tails in and out I find these excellent:
Thanks. Is there plenty of room to manoeuvre the armoured inside these?
That looks like it might be perfect. Looks like there will be plenty of room. Cost is not a problem for this job customer just wants it doing rightIf money not such an object then also the likes of these:
Schneider Electric SD1002SFK Sw Discon SP&N 100A
<p>Schneider Electric have now incorporated Square D, meaning an already well-respected name is now under the world’s specialist supplier and manufacturer of distribution equipment. This means you know you are getting a quality product when purchasing from Schneider Electric's range of light...www.tradesparky.com
But not very likely for domestic use!
I have a full meter box on the outside of the house.I like the bigger metal clad units if you have the room.
Do they still make those?I like the bigger metal clad units if you have the room.
I believe so about ÂŁ80Do they still make those?
The new ones (posted above) seem to have rather tight terminals and an odd internal layout.
Yes I do the same with rotary isolators.I always use the next size up and de rate the fuses
Reply to Switched fuse isolator in the UK Electrical Forum area at ElectriciansForums.net
