Switched fused spur problem | on ElectriciansForums
Discuss Switched fused spur problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
Lbd12345
Hi,
Had a problem recently. Switch fused spur fed off ring main to control 6 x t8 5ft fluorescent tubes works when it wants, tried replacing fuses and tried a new spur, and keep getting the same problem. Its not overloading and havnt come across this before.
Any ideas??
[ElectriciansForums.net] Switched fused spur problem
If it works when it wants, ask it why;). It's obviously throwing a tantrum due to a loose connection/ faulty unit.
Reply to Switched fused spur problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
