Switched fused spur used as throughway for control wiring | Page 2 | on ElectriciansForums
Discuss Switched fused spur used as throughway for control wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Reply to Switched fused spur used as throughway for control wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
It depends on where that SFU 'sits' in the circuit. If it's there as a courtesy isolator for the fridge socket then potentially yes as it could...
