Tail size what do you use | Page 2 | on ElectriciansForums
Discuss Tail size what do you use in the Australia area at ElectriciansForums.net
Dartmoor
Hi All,
When changing a domestic CU, I normally replace / upgrade to 25mm tails regardless of the main fuse size.
What do you guys do???, I was talking to a colleague who sticks with 16mm on a 60amp.
Answers on a postcard!!!:)
G
I tend to use 25mm tails on all changes. to allow for DNO fuse upgrades.
Although where I have to fit say an 80A switch fuse (due to the tails being too long) I will run 16mm if the volt drop is ok.
I nearly always fit 25mm tails.I have on one occasion left the 16mm tails in place when replacing a cu in a new flat because the position of the cu/head in a deep cupboard close to the ceiling would have caused undue strain on 25mm tails.Not to mention the strain on the paper thin walls and cupboard as I crawled in to bend the cables.
Made sure 60 amp fuse and correct Earth size.
whole exercise made me research some boards and connections and I found this'
Catalogues - consumer-units-enclosures-8804-100a - hager
The tail connector would have solved my problem
that seems like a good idea, what do they cost?
B&Q sell a 3m 25mm Meter tail kit (got caught-out on a Sunday and Screwfix were sold out)
Was reduced from £20 - £15, took it to the till and it was a tenner, was quite surprised.
They even stock MK 'Henly Blocks' too.
Reply to Tail size what do you use in the Australia area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
