Tails to consumer Unit | on ElectriciansForums
Discuss Tails to consumer Unit in the Australia area at ElectriciansForums.net
G
greeny
Hi,
Is there any reason why I cannot use 3 core 25mm2 SWA cable, from the isolating switch to feed a consumer unit.
Because I want to afford some protection to the tails from the kitchen fitters drillng and screwing.The consumer unit and meter cupboard are both within the kitchen and I want protection of some sort for the tails and I thought SWA is easier than drawning two tails and a 16mm through a large conduit
The 3rd core could be used for the PME earth 25mm instead of 16mm.
Reply to Tails to consumer Unit in the Australia area at ElectriciansForums.net
Not sure what you are saying in the section quoted so will ask you the question: Does a consumer unit have a main switch?
