Tails upgrade | on ElectriciansForums
Discuss Tails upgrade in the UK Electrical Forum area at ElectriciansForums.net
Davem
Hi, just a quick question I am upgrading a cu and partial rewire. Now the tails from the cutout are 16mm and go in to a teleswitch, they then comeout and go in to a multiwatt reader then in to the ccu. Obviously I want to use 25mm tails after the meter so do I get the electric board out to upgrade there part? Can the teleswitch be removed by them ? At my house supply comes in to cut out into meter then in to isolator then in to cu.! Any advice appreciated I am new to the game also so be kind
You would be wasting money getting them out to change their part, they won't be interested, 16mm is fine for almost all domestic applications, you may well find you have a 60A or 80A fuse anyhow. What they have between their cut-out aand meter is their property, I wouldn't even worry about it.
It's not your job to worry about the size of the tails on the supplier's side. And are you sure the tails on the consumer's side need 'upgrading'? Is the teleswitch no longer serving a purpose? If not, you would be lucky to get them to remove it. Depend who the DNO is, around my parts they would only remove when the meter is due to be replaced, unless it is in some way dangerous!
There is a mention of min. 25mm tails in the OSG, but no reference to any reg or reason as to this (if memory serves me), it is another page that may well be more useful as toilet paper. It's almost like they're dumbing things down so much in that OSG, like, "If we say to use too big every time then nobody can use too small. Doesn't matter if the reader knows how to work out the appropriate size for themselves or not.". Hic.
Reply to Tails upgrade in the UK Electrical Forum area at ElectriciansForums.net
I think it's more towards what the future brings with them and their ability to measure true power. Half remember a video from bigclivedotcom that...
