Tamper Proof Lights | on ElectriciansForums
Discuss Tamper Proof Lights in the Lighting Forum area at ElectriciansForums.net
Europe
Note Im 5'7" (maybe pushing the 7 maybe 6)
Funny thing someone pinched the Lamp Shades (Case) around LED lights on the Ceiling (NOTE i can touch this Ceiling without really jumping)
Its located in the Ladies Toilet of a pub, they want a replacement as you can TOUCH the LED lights.
I dont know what to suggest if they are just going to steal the Cover.
so i need some thing that you need to screw the case ON really
[ElectriciansForums.net] Tamper Proof LightsNOT LIKE THIS!!!
So no Thumb Screws or Clips (I hope) and with a Lowest Profile you can Go (how low can you go)
Trying to look around a few places and its hard to tell
I'm not sure that this suggestion is the best solution, but if you used the fitting illustrated, you could fit security nuts instead of the thumb nuts illustrated. Most sizes are available, and there are 'un-doable' versions available if needed.
Also Loctite would help! I guess visitors might continue to take it as a challenge!
Or maybe: 18W CCT Adjustable Circular LED Panel - 217mm | Knightsbridge (CPL18CT) - https://www.tlc-direct.co.uk/Products/GLCPL18CT.html?
Could still be ripped off the ceiling, but no tempting bits to unscrew!
Reply to Tamper Proof Lights in the Lighting Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
I would call an electrician.
Is it a aquarium with a lid or open topped? I made up something similar a few years ago with LED strip, an aluminium channel and clip in diffuser...
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
