If the junction box you refer to is on a lighting circuit protected by a 6A mcb or rcbo, or comes from say a 3A fused spur, then you could use that to feed a bell transformer for the doorbell.
You would need to use a transformer that is fully enclosed (ie insulated and with terminals covered)
Many are now designed to fit in the consumer unit, and would need an enclosure, - you could use this sort of thing:
(No personal experience of this supplier, this is an example)
Depending on the model of your Ring doorbell, you should check the required voltage of the transformer, and/or you may need to include a resistor in series with the connection, all of which is explained by Ring, and info is available on forums.![]()
Ring Video Door bell power supply bundle with Wylex ESE2 enclosure & BG CUB1
Wylex ESE2 IP40 2-3 Module Insulated Enclosure with BG CUB1 8 to 24 volt bell transformer. Works with most video door bells. for example: Ring, Google Nest, Eufy ESE2 Insulated enclosure for 2/3 Module IP40 rated, protected from tools and small wires greater than 1mm CE/UKCA/WEEE conformity...sunnyelectricals.co.uk
Yes that transformer unit needs to be indoors.Would the enclosure need to be indoors if tapped from the outside light junction box.so drill a hole through the wall?
I hadn't realised that your junction box was outdoors.
You need to ensure the IP rating is maintained by using suitable glands etc.
Prescribed zones suggest directly below or above where the cable comes through the wall.Brilliant thanks. So I need buy the glands separately I presume. Can I screw the transformer enclosure anywhere on the internal wall?
Is there a permanent 'Live' in the junction box or just switched live? (You dont want the door bell only working whilst the light is on)!Hey guys
Can I install a ring doorbell by tapping off a junction box going to the outdoor flood light ? Would I use transformer in between ?
Oh thanks never thought of that. There's a L , N , E in the junction box.Is there a permanent 'Live' in the junction box or just switched live? (You dont want the door bell only working whilst the light is on)!
Yes the transformer can go outside if mounted within a suitably IP rated enclosure.
