Telephone slave extension help needed | Page 2 | on ElectriciansForums
Discuss Telephone slave extension help needed in the UK Electrical Forum area at ElectriciansForums.net
R
ronbrown
Hi all. I'm currently trying to add a socket in an upstairs room from the master socket. At the master socket there is a 4 core cable where Orange goes to A and White goes to B and green and orange are cut back. At the slave there are 6 junctions with a 4 core cable with orange, white, blue and green. I've tried every possible connection of the colours in junction 2-5 but nothing works. On a couple of them the phone will ring continuously but none have the dial tone. Any help would be much appreciated
You need to connect to the highlighted terminals [ElectriciansForums.net] Telephone slave extension help needed
as said previously only 2 & 5 are needed connecting 3 can cause poor broadband speed due to interference
When punching cables down onto these terminals use a proper krone tool using a screwdriver damages the terminals and yes I have found sockets wrecked by people using screwdrivers
Constant ringing is caused by connecting 2 or 5 into the 3 on one or more of the outlets. Start at the incoming line, find a and b, put them into 2 and 5, use them throughout. Only old gear needs 3, and new gear is often not polarity sensitive. Just keep it the same throughout, if the polarity is a problem, you just have to swap them at the master.
Reply to Telephone slave extension help needed in the UK Electrical Forum area at ElectriciansForums.net
