Re: Tell us about your faults !
I have quite few list from USA side and some are pretty nutty.
Here one
Customer called me to find out why keep blowing fuses out every time the sump pump kick on .,,
found snakes in the pump no crap about it !!
Other service call .,
Customer compain the lights get bright and dim all over the house { remember in USA we have split single phase btw } so the customer did call the power company and they say their side is good nothing is loose so they told them to call the electrician so they got a hold of me I say ok I comming over and take a look .,,
check the main switch good .,,
check the netural good .,,
check the earth oh oh where is the earth connection
did do little more deeper digging and found water heater is shorted to earth and cause the earth conductor get frizted up btw yeah this is alum conductor { the USA code do not allow alum conductor for earth connection for safety reason} and to make it worst the next door house they have open netual
all the netrual current was running thru the copper water pipe that how it got burnt up !
France side .,
customer called me about the RCD failure ok., look at it found a mouse got between the active and earth conductor and replace it and fix the conductors up and seal up the holes good so the mouse can not get inside again.
Merci, Marc
