telectrix
Mentor
This month's Tel's Tip.
Ever been about to fit some pvc conduit and found you've not got your bending spring?????
Panic not.
Cuts 4 pieces of 10mm GN/Y singles to be long enough to go past where you want the bend. insert into tube , warm tube with hair dryer or friction, bend over knee or whatever method you prefer. remove bits of cable. Job done. ( this is for 20mm tube. work it out yourself for 25mm ).
2" where the elbow is next that big blob of cement. more like 3" further up.and it's the brickwork that's out, not the tube :)
Upvote 0
Only having a jest Tel, must admit I was never great with steel tube but I got by but with plastic I can loop the loop with no manufactured bends.
Upvote 0
unfinished. as the existing 10mm was in the way, i unclipped it. after the pic was taken, 10mm was re-clipped and cable tied to the tube. well spotted though.
Upvote 0
telectrix
Mentor
cheshire/staffordshire
United Kingdom
Electrical Engineer (Qualified)
Business Name
Telectrix
Tel's Training Tips - Education Tels Way
Electrician Courses : Electrical Quals
Thread Tags
telectrix,
baza890,
Electrical Courses
