temporary refrigerated container | on ElectriciansForums
Discuss temporary refrigerated container in the UK Electrical Forum area at ElectriciansForums.net
Tucson, AZ
I have a 3phase disconnect within sight of a temporary food storage container. I am supplying the unit with a 4wire cord. Do I need to add a disconnect switch on the unit?
Probably not.
unless you can see a reason why it may be needed
Reply to temporary refrigerated container in the UK Electrical Forum area at ElectriciansForums.net
Stick the socket in a large plastic wall box with hinge and padlock. Give customer letter with key...
4K
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
