I
Inteificio
Hi,
I had to do a repair I was not certain on, so would like to run it past some experts here.
We have a large stirrer at work. Due to some incompetence the gearbox got damaged.
With a lot of work we have almost everything back together with 1 problem remaining.
There is a lot of wear on the main drive cog interface.
With the motor as is, the massive start up kick combined with the slip on the box is enough to shear the cotter pin.
So I changed the wiring from delta to star to knock the torque down.
It now spins up slowly and well.
This leads to the problem of setting the overload.
There is a 9-13A overload on there, it was 13, I moved down to 9. A little high, but it got me thinking.
If the motor can run fine at 13A star, why can it not run fine at 13A delta.
I have a few ideas why, but I wonder if anyone knows?
