Terminal Block | on ElectriciansForums
Discuss Terminal Block in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Manich44
Hi All,
I have just fit 10mm splash backs in my kitchen bringing the sockets out by the same distance. On one of the double sockets I now have barely enough cable to work with and connect to the socket, I have 3 lives, neutrals and earths. Is it ok to use a terminal block to connect all like cables then run a single length from the other side of the terminal block,to act as an extension to the plug terminal?
Thanks.......
Three of each? Hmmmm..... Is one of those a spur going somewhere? In theory, if you're creating a junction like that, the socket becomes a spur and you'd need to limit the current supplied to that socket with a fuse.
Hi,
Theres a spur going to a fused switch which supplies a built in freezer,and ive added another to a socket in a unit which powers the ignition to a gas hob.
Reply to Terminal Block in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And with a duff one, it just sits there, not knowing which way to turn, but drawing considerably more than its normal run current.
Thank you for the prompt reply, much appreciated. The light fitting is metal and it does encase the connectors yes I will make sure it is...
