Terminating various Swa into Main Panel Board | on ElectriciansForums
Discuss Terminating various Swa into Main Panel Board in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Installing panel board,swa’s from 70mm to 16mm,all sub mains,using extension cableways,but struggling to terminate in the top areas,anyone know a better way,than steel trunking across the top of board.
Some boards have extension pieces you can buy that go on the top or bottom, to help with terminating wires.
[ElectriciansForums.net] Terminating various Swa into Main Panel Board
Personally I like to see a DB as a standalone install. Trunking mounted under and cables then made off into the trunking.
When designing I want to make future maintenance as easy as possible and a straight DB change is far far quicker without loads of cables made of into it
Reply to Terminating various Swa into Main Panel Board in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
