Termination of S W A into a plastic fuseboard | on ElectriciansForums
Discuss Termination of S W A into a plastic fuseboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
AA410
Hi good people can anyone tell me the best way to terminate a 16mm swa into a plastic fuseboard or is it best to fit a metal one your views please many thanks
Thanks for that you just made me look at the job in a diffrant way just hope i can get it to bend with a good radias the cable run is in a stud wall
I was only kidding of course... Never heard it called a frying pan before, but I think banjo is a pretty terrible thing to call them as well as they don't look like any banjo I've ever seen!
Hi AA410
You could use an earthing nut from SWA, this would allow you to go direct into the plastic and take a flying lead off the nut without the need for a frying pan.
25mm galve through box with an adaptor on and take it straight into the cdu having said that it depends on how many cores it has if its three phase then as malcom has said
How would you deal with 25mm SWA tho?
bigger box?
and malcolm beats me to it again. previous post mentioning earth nuts is the way i'd go. no need for banjo frying pan and much neater.
just flying to Paris, hear the restaurants have got fresh steaks. pre fried at newbury
Reply to Termination of S W A into a plastic fuseboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sounds more positive.
