Test equipment calibration | on ElectriciansForums
Discuss Test equipment calibration in the UK Electrical Forum area at ElectriciansForums.net
R
Rich-B
Hi all. I was wondering what you guys do when it comes to calibrating your testers. Do you send them away or do you use a calibration box or another method entirely?
Eitherway you will need them professionally callibrated. Check boxes are not callibration equipment. They only provide accuracy checks for you over the year(callibration period being 12months). Saves u potentially going back over months of testing if your meter has become faulty. E.g dropped out of an attic space for instance!!!
The scam bloke said to me you can send your tester for calibration every 3 years but you need a checkbox to check readings on testers every month (yeh right!!!)
So now your checkbox needs calibrating every year (what's the point to it all)
I always use on site calibration services OSCS and I keep a back up test set.Also useful if your gear gets nicked.
me too. he comes to you, so there's no down time and no carriage costs.
because some outfits will have several MFTs on the go........not to mention seperates (low resistance ohmmeters, high ohmmeters, loop testers, RCD testers)..then theres your other stuff such as a multimeter...certain clamps etc....so if you have quite a bit of stuff....all of a sudden a checkbox looks viable....
Reply to Test equipment calibration in the UK Electrical Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
The 1552, which I also own, does not predate GS38. You have nothing to worry about.
loz2754
L
