Test lead adaptor. | on ElectriciansForums
Discuss Test lead adaptor. in the Talk Electrician area at ElectriciansForums.net
G
Geordie Spark
I've just acquired a Metrel Instaltest 61557 & with it came a bagful of test leads & other bits 'n' bobs.
Amongst it all there is a normal looking rubber 13A trailing socket but on closer inspection, I found a 4mm test lead socket in the hole where the cable would go through if it were being used as an extension cable.
When I opened it up I found that all the terminals inside - earth, live & neutral are all wired together & to the 4mm test lead socket.
Can anyone please tell me what this is for?
Many thanks for your help.
What you have there is a simple adaptor more normally seen in PAT testing to allow a continuity test to be carried out on extension leads, the more common form is the plug version. The socket version is only usually used where a BS1363 13A plug supplies some form of non-standard socket/s for which a special plug adaptor would otherwise be required.
Reply to Test lead adaptor. in the Talk Electrician area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
