Griffey
Hi, I currently have a Megger 1730 v1 which is fine for all functions except the 2 wire (L-E) no trip loop test, (no 3 wire loop test on my 1730). It is absolutely useless as the site where I work has a noisy electrical supply (probably due to harmonic distortion, numerous large inverter drives). I can't really afford a 1741 which are suppose to be good, and would buy be willing to buy a separate loop test instrument or a less expensive MFT that would do the job. If anyone has any recommendation given the environment of use I should be grateful for advice.
My 1730 has recently been calibrated and works fine on domestic supplies!
Thank you Griffey.
Thank you Griffey.
