test meters digital and analogue | on ElectriciansForums
Discuss test meters digital and analogue in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bobby101
hello there could some one please tell me the correct settings on the analouge test meter for test sequences as follows:
R1 R2
EFLI
PFC
the college that iam due to sit my 2391 only had 1 meter between 15 of us and rushed all the testing sequence with said meter i am very nervous about using the meter i am not famailer with any help and guidance will be greatly appreciated :confused:
Nothing wrong with using your own meter. Cant be bothered with analogue myself but before anyone else can guide you whats the make and model as meters may differ in set up.
Good luck with the exam.
Chris
Hi,
each meter, anolog or digital will have a select dial for each test you want to carry out,
the differece will be how the test result will be read, analog you will have to be read using the correct scale to get the result of the test ,digital will give you the result of the test as a number
Reply to test meters digital and analogue in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
