test on a new shower circuit | on ElectriciansForums
Discuss test on a new shower circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
ambrad
Hi all
will be fitting new shower circuit with rcd shower unit. will be splitting tails with 100 amp connector blocks so circuit will be independant.
Does this have to be an eic or will it be acceptable to submit it on a minor eic.
recently been registered as a domestic installer so would like this advice so as not to noify this job and have it certified on the wrong sheet.
thanks
I am with Napit and they use: Minor Works/Single circuit Electrical Certificate.
I brought these from Napit when I joined.
I had never heard of these before joining they are different to the IEE certs, normally as stated above you cant use a MEIC for adding a new circuit.
Reply to test on a new shower circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
You made the mistakes of a) asking the wrong question, and b) asking it at all. If you ask them, then of course they'll gold plate their...
