Test the (RCD) Residual Current Device or die | on ElectriciansForums
Discuss Test the (RCD) Residual Current Device or die in the Lighting Forum area at ElectriciansForums.net
It is a bit extreme that warning.
maybe it should be a bit more of a recommendation than its current somewhat threatening language.
poor translation from german to english maybe?
or have they missed out the bit after Arc flash that reads Turn off power before removing cover?
Im not sure it may not be an official schneider label ,with the other problems i found here like a cpc used as a switch live. Probably not the best installler
At least here some facilities have also fake signaling indications..... It does not matter if you are a rookie or a high experienced electrician, always rely on your instinct and knowledge first and afterwards to the signals and labels.
Reply to Test the (RCD) Residual Current Device or die in the Lighting Forum area at ElectriciansForums.net
thanks for the confirmation this is what i thought. i cant think of what use this device is . i have seen David Saverys Arc Fault Detection Device...
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
