Tester | on ElectriciansForums
Discuss Tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
captain pugwash
Might be a silly question, but, if I test a contact on the 12v output side of a 240v to 12v transformer with a 240v electrical screwdriver, should it light up? It does on both terminals :confused:
I was introduced to Neon drivers as "plumbers drivers" very wary of them specialy when I know a guy who got a right good shock when his Neon broke
Reply to Tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Interesting. Sounds unusual since it seems it was very lightly loaded. Not much you can do I suppose other than buy a replacement unit. Unless...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
