Testing a Fused Spur | Page 2 | on ElectriciansForums
Discuss Testing a Fused Spur in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi mate not had it yet im doing things slowly, month by month as its costing quite abit for all the stuff i need.
Got testers now just had it calibrated, got a lock off device, R2 lead, R1+R2 plug top, calibration check box, test lamps, Insurance.
Next month gonna get all the books i need, roof rack ladders, conduit tube, then hopefully the month after ill pay the NIC and get my leaflets printed, if all goes well ill be able to start.
Reply to Testing a Fused Spur in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
There's a difference between being required to install an RCD and being required to have a full rewire when all the houses around have similar...
