Testing after a consumer unit change | Page 2 | on ElectriciansForums
Discuss Testing after a consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Had to change 40 consumer units the other day in a hostel/hotel/b&b and it come to the testing stage
I spoke to the NICEIC who said you need to test circuits for " safety only ". He said doing a global IR test (testing each individual circuit if less than 1M), and earth fault loop, RCD and end to end to any ring mains. He said not to bother with R1+R2 or R2 test as polarity would be verify due to the Zs test.
How much depth do you do?
Always do the tests before which are end to ends and Zs at every accessible point on rfc, lighting Zs but at switches if a ceiling full of downlights and dimmers involved, Zs on any radials. L&N - E ir for each circuit. Additionally when more than 1 lighting circuit I do a functional test (look) by disconnecting the neutral to make sure it is not affecting the other circuit (borrowed neutrals). After change Zs on a few random points and compare with original readings to confirm my earth terminations, Ze and rcd trips. Feels like an assessment answer!
https://www.----------------------------/media/1203/best-practice-guide-1-issue-3.pdf
Can I refer you to this document?
Majority of tests I do are before the board change..
No point in changing the board if the installation is knackered or full of faults
The way I read the OP is that they are testing already newly installed and live boards...
Not seen that before; a step by step guide on how to change a consumer unit..
what next.. electrics for dummies? ;)
Judging from dome of the questions asked, Charlie, seems like a good document to read before attempting a CU change!!!!!!!!!!!!
Brilliant.
Changed 40 in one day, wow. I know I am mainly a fire alarm engineer but even if there is only a lighting, socket circuit in each I cannot see how you can do 40 in a day. Even working a 20 hour day it’s two every hour.
Is that a trick question or do you genuinely not know?
Sorry
Yes I know it’s past , as in they have already done 40 consumers units
My point was if they have already done 40 and now looking at possibly doing some testing after the fact , then aren’t they putting cart before the horse
Reply to Testing after a consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
Hi Gingerrubix, The fact that your previous Tenant replaced a faulty socket plate which he used for an external EV, raises an eyebrow. Also your...
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
