L
lofty84
I have my 2230 testing and inspecting practical tommorow and I just wondered if anyone can tell me if Im doing things right or wrong.
The first test we will have to do is the continuity on protective conductors
For this I will select the low ohm reading on the test instrument and null the leads. Then I will take out the main bonding conductor from the main earthing bar in the consumer unit and applly a crocidile clipped lead to the end of it then with the other lead I will take it to the main bonding clamp and take a reading and then to the pipe work and take a reading. I would then record the highest value.
Is that correct please
sorry forgot to add that i will be expecting a reading of 0.05 ohms or less
