J
james king
can every one please ask sum Qs that they have had on there assessment i will try to asnewr to best abilty thannks.
Discuss testing assessment in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
What are the RCD disconnection times
How deep is the chase in a wall vertical
How high up from the worktop should the middle of the socket be
How close to a sink can you have a socket
Good luck
Chris
What are the steps for safe isolation
In a radial circyuit with a number of outlets where would you measure R1+R2
State 4 situations that require 30 m/amp Rcd
What are your disconnection times for circuits on different systems ie TT TNS TNCS.
Do you need to earth a metal back box.
What is basic protection.
What is fault protection.
What are the zones in a bath or shower room.
What are exposed and extraneous conductive parts.
Reply to testing assessment in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
