Hi there
I was called out to a job this week where clients bulbs are blowing frequently. I expected to test voltage for the property and see a high voltage around 245/250...
However when I arrived the client told me a previous electrician, who I spoke to on the phone whilst I was there, had measured voltage at the switch for kitchen/living area at 380-400V.
He therefore disconnected the lights as they were just blowing straight away.
I told customer that I couldn't reconnect these lights as it would be dangerous. Electrician also said that sometimes there was power coming to the switch and other times it was dead. He said that he thought there may be a crossover between the flat above and this one ie. kitchen lights supplied by both a circuit from this flat and one from flat above.
I'm going back when the neighbour from the flat above is home so I can isolate her power and see if that affects my clients lights - has anyone ever come across anything like this before? And any thoughts why there would be 400v at lights in one particular room and not throughout the whole house?
I was getting 245v through rest of the flat.
Thanks! Kelly
Thanks! Kelly
