Testing builders work | Page 2 | on ElectriciansForums
Discuss Testing builders work in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It is for same members of a company OR possibly a qualified sub contractor.
no , its not.
most design work on large commercial projects is carried out by independant consultants whom are completely seperate entities from the installing contractor.
Thanks for your inputs everyone. Oh and murdoch quite a lot of constructive response ideas and views on this subject but according you not a great first post obviously you know it all!
builders build, plumbers plumb (generally spelt BOTCH), plasterers make a mess..... sparks spark. end of.
The only difference between us all is, If we worked along side a Carpenter, within 3 months we could hang a door and fit skirting boards, work along side a plumber, within 3 months fit a central heating system, work along side a Bricklayer within 3 months be able to build a wall, if they worked along side us it would take them years to learn our trade.
You've listed 1 element of each of those trades' work.
It's like saying electricians only install Ring Mains.
Well....... I am well aware, as are the majority on here, that signing off EIC's and notifying a 3rd parties work is a no, no.
Reply to Testing builders work in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
