testing by megger info | on ElectriciansForums
Discuss testing by megger info in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
confused-fuse
some useful info for all students and electricians
  • [ElectriciansForums.net] testing by megger info
next set
Thats good you seem to get some good hand outs from college. We have some of these posters on the wall.
Any more hand outs on Inspection & Testing?
These were given out free by Megger to colleges in the form of big posters for the walls and files on a CD so the colleges could use them for presentations and handouts.
You can also see them and copy them from Megger facebook page
MeggerUK | Facebook
The site says - "These may be copied and freely used but under Meggers copyright do not modify them or remove the Megger logo's"
well spotted i did not even know megger was on facebook .. the collage i'm at do give alot of handout out and test sheets .. but thay will not pay for a new set of T&I dvd's as the ones thay had have gone walkies .. lol
its written on the side of the breaker!!!! either 6 or 10ka
or for supply fuse a bs 88 type 2 is normally 60/80a
bs 1361 type 2 60/33. some do vary tho
Nice to see clear pictures but you would have thought a firm as big as megger would get them correct
continuity of main protective bonding conductors MUST have one end disconnected,
and steps for testing ring final continuity. see GN3 there are 3 steps these are not the same as these pictures and will get low marks if given in the 2391 written exam. the first step is the only time you measure at the board. step 2 is measured between L and N at every socket not at the board. step 3 is measured between L and cpc at every socket there is no step 3a and 3b. the R1+Rn and R1+r2 at the board is by calculation only. pictures like this cause confusion to stuedents who have not yet got it. as always check all testing instructions against the inspection and testing bible AKA GN3
Reply to testing by megger info in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, Ive got a couple of Megger PAT 450 testers, and, for a number of reasons, Im not happy with the printer it comes with. Does anyone on here...
There is a lock on it, press the test button down and press the lock button, the symbol will appear on the screen in the middle right hand side...
