testing by megger info | Page 2 | on ElectriciansForums
Discuss testing by megger info in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello Confused-Fuse,
I found your megger info sheets very useful. I am still practicing on my Megger 1710. I thought that as Insualation Resistance test is a dead test so I can literally do this test on a cable which is in its pack. It was 1 mm2 twin and earth cable 21meters.
First I did the continuity test and it was 0.64 Ohms so it is ok for 21 m cable.
But whenever I try to do L-E insulation test nothing happens, however long I press the button. Similiarly L-N insulation test nothing happens.
Whats going wrong here, your help will be greatly appreciated.
Hi Rigby, by nothing happens do you mean the reading is 0.00M, if so have you removed the link you used during continuity testing?
I have never had a new mains cable on a reel go down when new and undamaged, but i have had data cable go down even on a new reel out of the box, so I always check data cables prior to installation
flash development team employs the latest versions of Flash programming languages such as ActionScript to gain better control and code reusability while building intricate and bespoke Flash applications for your specific business requirement. The flash development services that we offer include:
  • Flash Website Design
  • Flash Banner Design
  • Flash Template Design
flash software development
Reply to testing by megger info in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, Ive got a couple of Megger PAT 450 testers, and, for a number of reasons, Im not happy with the printer it comes with. Does anyone on here...
There is a lock on it, press the test button down and press the lock button, the symbol will appear on the screen in the middle right hand side...
