Hi
I was wondering and hopefully someone can point me in the ight direction.
All domestic installations should be certfied by either Domestic installer or Approved contractor as such.
My question lies within work done in a school, office, car garage or shop for example.
If you were part p registered can you or are you able to do installations in any of the above or do you need to then be an approved contractor via the NIC for names sake.
Hope this is clear lol.
cheers
Im a little unclear with the question, PIRs or installation or both ,but will give an answer that may assist
The first statement is incorrect(
All domestic installations should be certfied by either Domestic installer or Approved contractor)
Anyone can install and test and certify an installation The guidance they follow should be based on BS7671 but not exclusively(other standards may be acceptable,eg EU harmonisation)
However in the domestic sector electrical installations now come under part p of the building regs and compliance certification for those building regs are now required
The system in place allows the installer to notify building control before starting the domestic installation
The installer can if he choses join an approved scheme that will permit him to self certificate the installation without going through building control channels
In a nut shell the work needs to comply to a standard such as bs7671,but the person can chose the the route to comply
IF you join a scheme the approval is for the sector or sectors that they enroll you for
AN NIC domestic installer cannot use their forms for commercial or industrial work,the approved NIC contractor can
There is nothing restricting an electrician doing any work in any installation,the restrictions are imposed by the client and/or the scheme provider only
PIRs are not restricted to anyone whether they be domestic/commercial/or industrial anyone can do them,but there are sometimes requirements by the client that restrict this work for obvious reasons
With PIRs you are giving an opinion on the standard of an installation
IF something nasty occured and there was fire/injury or death then you could find yourselves explaining your actions in a court
You would need insurance to justify your opinions
You would have to demonstrate competence in the relative field (the 2391 would go a long way to doing so)
Clients or most clients require that you be a member of an organistion NIC ECA NAPIT etc
THose organisations restrict the issuing of PIRS on their paperwork unless competence is demonstrated to them,
Again in a nutshell,you can do any electrical work as long as the client accepts your status, irrelevant of training qualification or competence
If you are registered restrictions are per their rules
