Testing during a consumer unit change | Page 2 | on ElectriciansForums
Discuss Testing during a consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
TJC1
United Kingdom
Evening all
When doing a consumer unit change, how much dept do you all go into? Do you treat it like an EICR with 20% ish and spot checking?
Normally we do end to end, r1 or r2 and IR test once the old board is off and Zs when the new board is on. We try and find end of the line on each circuit and also spot checking.
Didnt know if there is an offical reg/ruling of how much you should do
I do a full EICR before the board is removed from the wall.
Do you charge that separately, or is that inclusive of the price for a CU change?
I only ask, as some, for an EICR, appear to charge fixed price & in addition price per circuit?
As we're in open forum, lets say a silly price of £500 & £50 per circuit for the EICR, then £1000 for the CU change (normal 3 bed domestic property, dual RCD CU).
I just used just charge the £1000. However, I'd carry out some suitable testing, the day or so before.
You’ll need to test the tails being connected to the new CU.
Inspect the earthing and bonding to ensure they are adequate.
Test any RCDs or RCBOs you install, and test any circuits below 16A to ensure Zs is low enough. Unless of course, the board you are changing has MCBs.
Which out for borrowed neutrals on the lighting.
Reply to Testing during a consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
I will offer some initial thoughts. A workplace so the EAWR 1989 applies, it is statutory and carries legal consequence drawing its authority for...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
