J
James Sutton
HI All
Have just installed a new circuit to supply power to a control panel.
Have tested it all came back fine if i need to carry out a ZE test how can this be done because cannot isolate the main board so cannot disconnect the Main CPC from the MET
Also have only carrird out a ZS at the furthest point of my installation which is the Switched Fused Spur
Should i do a ZS and PFC at the dis board or is at the spur fine
All results are recorded on schedule of test results the Red NIC forms. EXCEPT on the top left of the form where its asks for ZS AND PFC
Thanks just need a little guidance
James
James
