testing help | on ElectriciansForums
Discuss testing help in the Australia area at ElectriciansForums.net
Hi bonjovi, the RCD requires a good earth fault loop path to operate correctly, so if you test the RCD first and the earth fault loop impedance is to high and untested at that point your initial results would show that you have a faulty RCD when there is possibly nothing wrong with the unit. Always do the Ze first.
Reply to testing help in the Australia area at ElectriciansForums.net
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
